Tank Position
Frank Skilbeck
Tank Position
Postby Frank Skilbeck » April 18th, 2020, 1:35 pm
Just finalising the tank position in a new model, NGH38cc FS with Walbro carb. Best place for tank is with tank center line about 40mm above the carb center line. I understand that tank position isn't critical with a Walbro carb, so having the tank higher than the carb shouldn't be a problem, is that correct?
Glenn Masters
Re: Tank Position
Postby Glenn Masters » April 18th, 2020, 4:13 pm
That is correct Frank . . the carb itself will regulate the fuel flow through the regulator valve. Having the tank a little higher will help with fuel draw from a cold start . . . cheers
Frank Skilbeck
Re: Tank Position
Postby Frank Skilbeck » April 18th, 2020, 8:37 pm
Thanks, that's what I thought but wanted to confirm before I build the tank support.
