Postby Phil Clark » February 8th, 2011, 11:26 pm
Following delivery of the 1/6 scale B-26 last September, the latest project to reach completion is a 1/5 scale 'FW190 D9' built from the SisT Modellbau kit. At 83" span and 81" long, this full composite model has been finished in the marking of Josef 'Pips' Priller of JG26 in early 1945.
Power is from a ZG45 with a custom st/st muffler mounted inside the fuz behind the firewall. Retracts are Sierra all round, as are the wheels. Radio is JR/Spectrum AR9000 with 2 additional satellites, 2 HD switches and a 3,300Mah 6v NiMh pack. 10 serves are fitted being a mix of JR & Hi-Tec.
Paint finish is exclusively 'Warbirdcolors' with a matt 'Klass Kote' epoxy clear coat. Being that this aircraft was operating in the winter of 44/45 on the eastern front in far from ideal conditions, though it was a relatively new airframe, it was VERY dirty.....hence the high degree of dirt and grime applied to the surface.
Cockpit interior is from InZpan with additional items scratch built by us. The pilot figure is also from ourselves and has been fitted with a 'Photo face' produced from archive photo of the original pilot. The drop tank & pylon are also additions from our own kits and can be dropped in flight.
At this time, the model is complete and the TX programmed ready to go. Tomorrow will see the CG checked (allowing us to get an idea of the AUW) and initial engine runs down on the new ZG45. I've been tasked with the test flight of this model, so more news as and when I have it....
- SisTD9_112.jpg (52.65 KiB) Viewed 11475 times
- SisTD9_113.jpg (58.39 KiB) Viewed 11475 times
