3 phase to single phase
paul hughes
Postby paul hughes » March 1st, 2012, 9:11 am
Can anyone help, I have aquired a boxford lathe but it is designed to run on 3 phase power supply. Is it possible to buy, or does anyone have one to sell, a converter to switch from three phase to single phase electric? The main drive motor is about 3/4 hp.
nickhenderson
Re: 3 phase to single phase
Postby nickhenderson » March 1st, 2012, 8:06 pm
Paul,
like most things in life, you get what you pay for. Phase converters are readily available both up and down ie 240 up to 415 or vice-versa. Price wise, new from around £125 upwards depending on spec etc etc.
Sorry but i havent got one you can have, however as said, they are out there.
Nick
Postby Tony Collins 1073 » March 1st, 2012, 8:59 pm
Here you go Paul. A new digital Converter for seventy quid + 8 for postage unless you can collect from Nottingham.
Good luck.
http://www.ebay.co.uk/itm/IMO-1HP-240V- ... 4ab49aebcd
NB these I think are the drawings.
OR
A used one of the same make as above going on Ebay.
http://www.ebay.co.uk/itm/IMO-1HP-3-PHA ... 58923f953b
If you need any help on the bidding side PM me. I know the ropes very well.
If you do decide to bid, do not I repeat do not enter an automatic maximum bid figure. It will just help the other idiots to push the price up.
Andy Boylett
Postby Andy Boylett » March 1st, 2012, 11:31 pm
Paul,
As said below you need an inverter. These units simply use modern electronics to convert a single phase supply to a 3 phase one. However, be very careful when buying a cheap inverter unit. Many of the sellers are very coy and don't mention that most of these units convert 240volt single phase to 240volt three phase. A true 3 phase supply is 440 volts (or 415v in new EU rules) between the phases - voltage measured between any 2 out of the 3 wires. The cheap units are only 240volts.
What does this mean for your machine? Well if your motor is rated as 440v/415v and you use one of the cheap units then it will only run at 240/415 = 58% of the speed that it is supposed to. Also, if there are any other electronics in the unit that needed the 415v then they will likely not work.....a lot of machines have 240volt electronics powered from the 3 phase supply by a connection between 2 phases, which gives the 240volts. With the cheap inverters this 'between phase' voltage is 140volts and usually the electronics will not work. Lots of sellers now also supply 3 phase motors designed for 240volts !!!
BUT, if your machine is rated as 415/240v then you can use a cheap inverter and change the wiring connection to the motor so that it still runs at the correct speed.
I have installed a 3 phase ring main in my garage. It supplies a surface polisher, milling machine, lathe, grinder and power cut off saw. I bought a 5hp inverter and it supplies the ring main.
Cheers, Andy
Postby Tony Collins 1073 » March 2nd, 2012, 1:10 am
Paul, Drives Direct in Nottingham are not a twopenny halfpenny firm and the Ebay auction which is from Drives direct Categorically states this converter is ok for a Boxford Myford which is what you have. If you are in any doubt then phone them. They have a considerable website and three phone numbers to contact and it will be in their own interests to put you straight regarding the voltages mentioned by Andy.
Tony
Last edited by Tony Collins 1073 on March 3rd, 2012, 9:57 am, edited 1 time in total.
Barrie King
Postby Barrie King » March 2nd, 2012, 10:21 am
Hi Paul, try transwaveconverters.co.uk they attend most model engineering shows and will be at Manchester this w/e
Barrie
Andy Boylett
Postby Andy Boylett » March 2nd, 2012, 10:31 am
Paul,
Should have said.... Drivesdirect is where I got my inverter too. :D
If you tell me (or them) what it says on the small plate attached to the drive motor then I can tell you which type of inverter suits your machine. If the motor is dual voltage 415 and 240 (both 3 phase) then there is just a simple wiring change to convert it from 415v to 240v three phase, and so able to use the cheaper inverters.
Cheers, Andy
ps. if you want to run other machines on 3 phase as well I have a spare 5hp inverter, brand new. I bought a really old machine that could only run on the full 415v. This one was £500 and I am about to list it on Ebay at £300. it is the type that prduces 3 phase at 240v.
paul hughes
Postby paul hughes » March 2nd, 2012, 1:31 pm
Thanks for all the great imput guys, It gives me something to work on over the weekend.
Mark Partington 2989
Postby Mark Partington 2989 » March 2nd, 2012, 4:41 pm
Andy Boylett wrote:Paul,
Andy, WRONG!! - the one thing he doesn't need is an inverter - when will people learn that an inverter converts DC to AC -ONLY!! Single phase inverters are the usual ones you'll find in caravans OR if you want to run your lathe off a battery then three phase inverters are available.
As said above, he needs a phase convertor.
Mark.
Tonka Toys, Big Boys Toys
Andy Boylett
Postby Andy Boylett » March 3rd, 2012, 5:49 pm
I was trying to keep it simple in order to help someone. I said repeaedly in the my text that it needs to be three phase and that the cheaper units convert to 240volt SINGLE PHASE to 240volt THREE PHASE. Also, for those with little knowledge searching on "415v inverter" on Ebay gets you lots of the correct items......
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=415+inverter&_sacat=See-All-Categories
If he contacts me or diect drives we wil sort him out with the correct gear. I have my own 240 sigle phase to 415 3 phase set up as a complete ring main in my workshop. Two of the motors on one machine had to be switched from delta to star. I also have a phase regulating circuit for my antique Herbert milling machine as it did not like the slightly lumpy sinewaves it got.
paul hughes
Postby paul hughes » March 4th, 2012, 6:28 pm
now sorted thanks. got a unit from the north modelling expo this afternoon.
Postby Mark Partington 2989 » March 4th, 2012, 8:00 pm
Andy Boylett wrote:Nope, don't be daft Mark, you know I am a Chartered engineer and do know about these. I was trying to keep it simple in order to help someone.
Andy, yes, so you keep telling everyone - however, we know it's not aeronautical, mechanical or structural, now we can include electrical engineer in the list of what you're not.
An electrical engineer would never describe a phase converter as an inverter, and as for trying to keep it simple -all you managed to do was tell someone to buy the wrong thing and link to something different. Now, when you're talking about lethal ac voltages, that's just plain irresponsible and bloody dangerous!!
Mark.
Mark.
Andy Boylett
Postby Andy Boylett » March 4th, 2012, 10:07 pm
Glad you are sorted Paul.
Dave Parry
Site Admin
Postby Dave Parry » March 4th, 2012, 11:36 pm
Forum Administrator’s Warning
Now I have tried my best not to step in here but you two have left me no chose. You both have a difference of opinion about this issue and I don’t care who is right. Andy you cannot call someone daft and expect then not to be offended and upset as this show signs of trying to belittle someone by persisting you know better, I know you are not like this in person, as I have met you. Your forum manner can be very off putting at times, and I think you need to think before hitting that button. Now on the other hand Mark you are also coming across and being aggressive with your first reply which I think started all this off by shouting WRONG!! This also is a sure sign of getting someone’s back up too, I am sure Paul didn’t want you two, to start a slanging match on his thread, so please put this to bed before I do.
Andy Boylett
Postby Andy Boylett » March 4th, 2012, 11:46 pm
Sorry boss, I am suitably chastised :cry: :cry:
Postby Mark Partington 2989 » March 5th, 2012, 8:16 am
Sorry Dave - pm sent
Mark.
PHIL ATHERTON 2400
Postby PHIL ATHERTON 2400 » March 5th, 2012, 3:27 pm
[bWho's WONG dave have not seen a chinamans reply to the thread :lol: :lol: :lol: ][/b]
Dave Parry
Site Admin
Postby Dave Parry » March 5th, 2012, 6:22 pm
:lol: :lol: :lol: nice one Phil well spotted, Now amended.
Users browsing this forum: No registered users and 52 guests
