Help please - Graupner Ultra Duo Plus 60
Kevin Turland
Postby Kevin Turland » May 25th, 2014, 5:54 pm
The manual says I cannot use two charging outputs at the same time, is that so? I bought this charger fully understanding that output 1 & 2 could be used simultaneously, I would appreciate any help on this from anyone who is familiar with the charger.
Re: Help please - Graupner Ultra Duo Plus 60
Postby Alan Cantwell 1131 » May 25th, 2014, 6:49 pm
Getting started ULTRA DUO PLUS 60 Order-No. 6478 Warning: The software does not take the output current of Output 3 into account when it calculates the charge power. This means that the charger will re-boot if the internal mains PSU is overloaded. If devices with a relatively high current drain (more than 1 A) - such as Peltier coolers or heating covers - are connected to the unit, we therefore recommend that you use only one of the two charge outputs, and set the power distribution to 50% / 50%, in order to prevent overloading the internal PSU.
taken from the on line manual, any good??
Kevin Turland
Postby Kevin Turland » May 25th, 2014, 10:07 pm
Allan thank you
