OS 40
Gerard Jordan
OS 40
Postby Gerard Jordan » August 19th, 2009, 7:09 pm
Information required on an old OS 40. If anyone can help please email me at gerard.2@virgin.net.
Re: OS 40
Postby Tony Collins 1073 » August 19th, 2009, 9:33 pm
What the heck Gerard.
If you want help you are going to have to be rather more explicit in your request than that. :? :? :?
Gerard Jordan
Re: OS 40
Postby Gerard Jordan » August 20th, 2009, 5:47 am
Hi Tony,
Im trying to tune an older moodel OS40, ( before the FS max series,) and I dont think it is delivering enough Rpm / power. This is the engine you flew for me at Binham, which was since set up by an `expert` The two screw adjustments on the carb are difficult to set up in sympathy. I dont have much of a clue with this motor, as to setting it up, perhaps you can give me an idea if you know this model Just Engines seem a bit of an overkill for this problem. Its also a lot more difficult to start than it was at Binham.
Regards Gerard
Re: OS 40
Postby Bob Thompson1894 » August 20th, 2009, 5:58 am
Gerard- if this is an old OS Max, then the needle is probably worn, making it difficult to tune. They leak air into the spraybar, sometimes a bit of fuel tube over the threaded part can cure it. If not, you can get a new one from John D Haytree, tel 01626852330. He stocks parts for all engines.
Gerard Jordan
Re: OS 40
Postby Gerard Jordan » August 21st, 2009, 4:40 am
Thank you Bob, I`ll try that
regards Gerard :P
andywynn
Re: OS 40
Postby andywynn » August 21st, 2009, 9:02 am
Have you changed fuel? If the engine has been run over its life time then it will have been run on castor based fuels (Good ole days :D ) I've had issues in the past when switching to bekra (fully synthetic). They need about a gallon through them running rich to clear out the carbon deposits from the previous fuel. Even then they don't clear up completley. :cry:
Also not sure on that model but OS went through a stage of using air bleed carbs, worth checking if it has one as that could be partially blocked, remembering the mixture adjustments is the opposite to a normal carb.
Hope that helps
Andy Wynn
Gerard Jordan
Re: OS 40
Postby Gerard Jordan » August 25th, 2009, 6:22 am
Thank you Andy
Gerard 4001
