My issue/concern is: do I need to mass balance the Aielerons or not. So like most I trawl the web and come up with more confusion than when I started.
I understand the principals of mass balance and have used it in the past on smaller stuff, by putting weight into the tips of the aielerons where they have the extensions that fit into the wing tip. Simple enough, but on the Yak although I have cut outs at the end of the Aielerons to facilitate the idea I dont want to add weight there. I figure my roll rate would increase but stopping it rolling after inertia takes over might be an issue
So if it is necessary I want to go the spade route as per scale to full size. These would be fitted about 1/4 of the way up the Aieleron so the weight is inboard not at the tips.
I accept flutter can be induced by several factors ie, rigidity of surface, airflow,air speed etc. But has anyone got any advice on this one. It is also stated somewhere on the WWW that the spade also exerts an aerodynamic load when it is digging the air, another consideration( or not).
Each aieleron is 1.8m long and 220mm wide,4 x20Kg servos in pairs driving 2 mount points equal in distance to each other and the hinges etc are scale. I guess with 210 Lb of static thrust on a 115Lb model and taking into account drag etc. it will have a max speed of 50/60mph.
any thoughts or am i getting a bit anal about it.
