Looking for some advice on the starting tecnique of torquemaster with an easystart.
Engine runs perfect and starts easy without torquemaster.
With torquemaster engine gives a slight crack and slight puff of smoke from exhaust but won't run.
If i drive prop through all magnets the prop tends to slip and won't go over TDC. If i take the prop to compression and then flick it will drive over TDC. Don't want to tighten belt much more as starting to put downwoud pressure on crankshaft.
Thanking you all
