ALUMINIUM BAR
Posted: February 23rd, 2011, 1:05 pm
Can anybody supply me with the following Aluminium bar, 22mm square x 50mm long if possible with a 16mm hole
bored through the length.Material only will be ok as if necessary i can do the bore myself.
I require two pieces for the job in hand,but if possible make it four then i will have two spares.Many thanks Brian..
