Multiple servo wiring
Posted: April 4th, 2011, 7:33 pm
I am using multiple servos to control the elevators on my Pitts special, two hitec servos that will have the control arms connected by adjustable linkages. The servos don't have the high voltage connection so they can't be connected directly to the battery.
I am unsure how to wire two servos on the same channel without overloading the receiver with the current of two servos. Basically, I didn't think it wise to solder two servos together on one coonector into the receiver. Have you done this, did it work or did it fail?
How have others gone about this, what are your suggestions?
