DWG drawings
Posted: January 20th, 2013, 10:51 am
by AndyHopwood
Will the dwg drawing files loads onto autocad ok ? I got a free dwg software and wanna design a plan off my paper plan then save it so I can rescale it and sent it off to be printed. Just wondering cheers
Re: DWG drawings
Posted: January 21st, 2013, 11:19 am
by Stuart Solomon
Andy, DWG files are a native Autocad format so they should import into Turbocad. When finished save them as a DXF .
Hope this helps. Solly.
Re: DWG drawings
Posted: January 21st, 2013, 6:24 pm
by AndyHopwood
Turbocad. Right. So the printers use dxf ? I have never used autocad or turbocad. Are they same or different two package ?
Re: DWG drawings
Posted: January 22nd, 2013, 10:28 am
by Stuart Solomon
Re: DWG drawings
Posted: January 22nd, 2013, 7:27 pm
by AndyHopwood
Right. Yeah if u don't mind making a copy that would be great. Hope I don't put u out of your way to do this for me ? Be great if I can transfer my paper plans to dxf files and rescale it
Re: DWG drawings
Posted: January 23rd, 2013, 12:56 pm
by Allan Griffiths
Andy.
I use Aotocad LT ind Autocad inventor. i can open DWG etc for you, i also have a copy of turbo cad. IF you need a file opening etc, then i can do this for you. P>S i am in the same club as you! Wrexham. (i think)
Re: DWG drawings
Posted: January 23rd, 2013, 7:47 pm
by AndyHopwood
Hi Allan. Yeah u the nutter that flies plane like manic and put the plane in non normal flying pattern lol !! Yeah but I want to copy the paper plans which I have a few onto dwg or dxf files etc so I can then rescale it etc I have a dwg viewer but not drawing if u know what I mean. Stuart. I didn't realise turbocad cost a packet !!! I just looked up and do research
Re: DWG drawings
Posted: January 23rd, 2013, 9:27 pm
by Allan Griffiths
Andy, do you have a plan you want to scale up? if so then take it to a printers. they will scan it and scale it up. or if you have a CAD file with a dwg on then i should be able to scale it up but you would still need to print it which sorry i cant help with as i do not have a plotter,i know a company which does but would charge you.
Turbo CAD is very cheap for CAD software. I use Autocad inventor in work which costs around £8000 (eight thousand pounds) AutoCAD lt (2D package) is around £800. Turbo cad is very capable for the
money.
Re: DWG drawings
Posted: January 23rd, 2013, 11:06 pm
by AndyHopwood
Allan. Perfect you made and explained it so clear. Thanks. 8000quid Cor !! I do have a cd of plans A to Z of planes. Wish I have a0 size printer lol. So where is the nearest printer around Wrexham ? I could make a copy of cd if u want a copy?
Re: DWG drawings
Posted: January 24th, 2013, 2:42 pm
by Stuart Solomon
Re: DWG drawings
Posted: January 24th, 2013, 8:11 pm
by AndyHopwood
Yeah I will have a copy if u don't mind ?
Re: DWG drawings
Posted: January 25th, 2013, 3:39 pm
by Stuart Solomon
Andy, e.mail me your address and I will stick it in the post
askus@onebyone.co.uk
