Twin electronic ignition
Posted: February 6th, 2014, 10:10 am
by barrie burton
I have a twin electronic ignition unit that was used in a now defunct twin.I want to use it on a single cylinder engine.Can I simply use one lead only or do I have to put an unused plug in the second lead? Thanks in advance
Barrie Burton
Re: Twin electronic ignition
Posted: February 6th, 2014, 10:26 am
by paul hughes
hobbyking do a replacement unit for £23. is it worth messing about?
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Posted: February 6th, 2014, 10:44 am
by Peter Clare
Octopus RC also list a good range, I've had good service from them. But stick with the RCEXL brand
(not the XYZ ignition ).
Posted: February 7th, 2014, 7:44 am
by John Greenfield
Hi Barry
to answer your original question, you will have to put a plug in the unused cap or you will damage the ignition. The problem then is you will have an unshielded spark somewhere on your model and even 2.4 ghz radio does not like that.
Posted: February 7th, 2014, 8:35 am
by barrie burton
Thank you folks.It looks as if I am being directed along the route of spending some money.
Barrie B
Posted: February 28th, 2014, 11:33 pm
by ian redshaw
Hi Barry, I have a couple of CH single cylinder ignition units and sensors that I don't need, if they are of use PM me your address and I'll post them off foc, they aint no use to me.
Cheers, Ian.
Posted: March 1st, 2014, 12:46 am
by Denis Brown
Thats a very nice gesture
Posted: March 1st, 2014, 8:44 am
by barrie burton
Many thanks Ian,I have sent you a PM,you should also have received info on silencer design via a previous PM
Keep designing,building and flying,we are a diminishing breed
Barrie B
Posted: March 6th, 2014, 9:33 am
by ian redshaw
Denis Brown wrote:Thats a very nice gesture
Do unto one......... and all that guff!!
Posted Barrie, hope it is of use!
Ian.
Posted: March 6th, 2014, 3:26 pm
by barrie burton
Many thanks Ian,I will let you know the results.
Barrie B
