t180 build FG Cowling
Posted: March 3rd, 2015, 12:21 am
by richard armstrong
Hi all
need some advice got the FG cowling for the T180, i am fitting a electric motor,
if i fit the motor direct to firewall i am 2 1/4" short of prop drive
the option are
cut cowling back 2", for protrusion
add a block of wood til prop drive is out of cowl
make a long metal bracket and mount the motor
advice please on best solution
Re: t180 build FG Cowling
Posted: March 3rd, 2015, 7:31 am
by John Greenfield
Move the motor forward to align with the front of the cowl. with the light weight of a typical electric motor you need to get the weight as far forward as possible.
Posted: March 3rd, 2015, 8:42 am
thanks john
would you use a block of pine to extended or make a aluminium bracket, using 2 - 3mm standard flat ali be ok ?
time to get some card board out and make a mock up
Posted: March 3rd, 2015, 11:43 am
by Bob Thompson1894
Plywood is the answer. A block of pine will split. Just make a box out of 1/4 ply and epoxy together and to the firewall. 21/4" is a lot to pack out or make standoffs. Drill some holes through the joints and epoxy some thin dowels though the joints for strength.
Posted: March 3rd, 2015, 12:17 pm
thanks bob
just gave a light bulb moment
i have a metal lathe, Stand off why the hell did i not think of that, DOH!
using part wood part ali stand-offs will do the trick and give me a bit more nose weight as well
thanks bob you are a star
Posted: March 4th, 2015, 1:59 am
by paul needham
Richard, just make a plywood box like Bob says, keep it simple rather than useing part wood and part ali stand offs.
Posted: March 4th, 2015, 9:20 am
thanks paul
box is being been made up using a mates cnc router. i ditch the stand off as the impractical after i mocked it out with cardboard
