Zenoah 23/26 silencer question
Posted: January 30th, 2017, 7:30 pm
by David Baker
All
Can anyone tell me..
Will a Zenoah 23 silencer fit a Zenoah 26??? i.e. Are the stud centres the same?
I need to find an alternative silencer for my 26 with the outlet on the opposite side to the one I have (so I can keep it in the cowl)
David
Re: Zenoah 23/26 silencer question
Posted: September 14th, 2017, 9:43 am
by Clive Hall
I think you will find that the Zenoah 23 and 26 silencers are identical, they have the same bolt spacing. I also discovered that one of them will fit nicely on a DLE20. The bolt spacing is not exactly the same but the DLE bolts are a bit narrower and the holes on the Zenoah silencers are a loose enough fit to accommodate the DLE20. The Zenoah exhausts make a significant difference to the sound levels and general running of the DLE20. The change from the horrible din the DLE supplied exhaust amplifier makes is impressive.
