Phil Clark wrote:Small hatch Richard......a large upper hatch incorporating canopy will cut through the upper main fuselage longerons, so is to be avoided.
Alan Cantwell 1131 wrote:Does it need one? There’s a big hole underneath we’re the wing sits?
Charlie Cox wrote:Sliding canopy perhaps.
Charlie
Phil Clark wrote:Lithoplate with a section of the models balsa skin bonded on the back.
Location wise.......get yourself a good P-47 3-view set of drawings & find a convenient sized/located hatch on the forward fuselage........if you're going to add a functional hatch, you may as well put one in a scale location.
......you'll find there are several suitable options on the port side of a P-47!!!
