Wire Bending
Posted: October 17th, 2009, 3:31 pm
by Alex Murison
Hello,
Can anyone recommend anyone in the UK who can bend 5mm wire (Hostetler Jungmeister cabane and undercarriage)? I have emailed a specialist firm in the States but they may no longer be current as they have not replied to several emails.
Also can I borrow, or obtain a copy of, a Tartan Twin 44cc Manual? I will be pleased to reimburse your costs. Thanks in advance for your help.
Regards,
Alex Murison.
Re: Wire Bending
Posted: October 17th, 2009, 9:22 pm
by Barrie King
Hi Alex,
Is the Tartan Twin manual you want for the petrol or glow version, I have a glow one somewhere in the loft.
Barrie
Re: Wire Bending
Posted: October 19th, 2009, 7:32 pm
by Alex Murison
Hello Barrie,
Thanks for responding. I have the glow version - the prop driver on my engine has cracked and is unuseable - I believe that later versions have a more substantial driver without the six bolts. I am trying to locate a spare driver with little success so far and the manual will be helpful as I may be able to get a replacement turned by a friend who has access to a lathe. A photocopy of your manual will be very helpful as my engine was obtained used minus manual.
Regards,
Alex
Re: Wire Bending
Posted: October 20th, 2009, 8:43 pm
by Barrie King
Hi Alex,
I have found the manual which is just a double sided glossy A4 sheet with set up instructions on one side and a full exploded view on the other. It does show the multi bolt prop fixing. I changed mine years ago to a single bolt fixing without any problems. If you let me know your email address I will scan and send a copy of the manual.
Barrie
Re: Wire Bending
Posted: October 22nd, 2009, 7:28 pm
by Alex Murison
Hello Barrie,
Looks like the original prop driver may not have been up to the job!
My email address is
alex.murison@talktalk.net. Looking forward to reading the manual. Thanks for your help.
Regards,
Alex
Re: Wire Bending
Posted: February 4th, 2010, 12:29 pm
by Alex Murison
Thanks to Barrie King & Michael Ronan for responding. Tartan Twin info received and I am going to build a heavy duty wire bender! Alex Murison
