Walbro Fuel Inlet. Removeable?
Posted: July 6th, 2019, 8:09 pm
[img][/img]
Hi All,
On a Zenoah 38 when fitted with a carb bend, the fuel inlet is turned to be adjacent to the exhaust and points straight toward the silencer. In use the fuel pipe softens in the heat and kinks, cutting off the fuel supply (and it a potential fire hazard)
Pic for info shows the fuel inlet on another Z38 carb without carb bend.
Can the fuel inlet be removed and repositioned at a different angle? I thought that I remembered something about this on the forum some time ago but I may have dreamt it.
I've tried gripping the inlet with pliers and it feels rock solid so before I broke/ruined it, I thought that I should seek some advice from The Collective.
Thanks in advance.
stu knowles
Hi All,
Thanks in advance.
stu knowles
