Slow moving servos
Posted: October 30th, 2020, 10:10 am
Hi
I'm currently fitting out a Sky120 with Spectrum AR8010T receiver and 4Max metal geared servos and have a strange anomaly . When I first power up the receiver if I waggle the rudder or elevators (2) all the surfaces move slowly for the first 5/10 seconds then it clears and I can't get that to happen again , haven't tried the ailerons yet as I need good weather outside to put it together. The voltage isn't sagging on the 2000mAh Life battery and if connect a servo tester and test the servos are fine from cold . Any ideas anyone , I used a new model memory on the DX8G2 transmitter so there shouldn't be any odd things in programming . It isn't the end of the world but irritating because I don't know the cause .
