Ferrite rings on servo leads
Posted: July 6th, 2011, 7:24 pm
On some large models where the servo leads can be longer than 1 metre, I am aware that ferrite rings are used on the servos leads to increase the lead inductance and provide a more reliable data link. I have observed jittering servos myself with long leads although it is not always repeatable.
In an ideal world the servo leads would be treated as a classical transmission line and be terminated at both ends with 50 or 75 ohms. Lead length is then non critical. Power considerations do not allow us to adopt this approach in our models although it is used in the fullsize world e.g the 1553 data bus as on most military aircraft.
The use of ferrite rings on our models is a sub-optimal but practical approach but I have not seen any good practice guidelines for use on large model. e.g Where in the lead should the ferrite ring be placed - Rx end , middle or the servo end ? How many times should the lead be looped through the ring - this effects the inductance value ? What is the minimium lead length to use a ferrite ring ?
Has anyone any practical or theoretical advice on these issues and should such advice be in the LMA Handbook ?
