Twin Batterys
Posted: March 19th, 2017, 7:58 pm
HI.
I would appreciate sum advice
The story so far,i am running two lipos through a voltage regulator with two outlets into one Rx, no problems.
My current build has quite a lot going on in the wing so I wont to fit a second Rx in the wing, using the Lipo`s in the fus for power.
Now I can use one battery' for each of the Rx`s, but then I loose the redundancy offered by the two battery's, so, can I "Y" lead the two battery`s together, then run a Reverse Y lead ( probably not the correct terminology ) out to each Rx ,so giving each Rx the benefit of two battery packs .If this is possible I feel the dreaded diode debate may rear its head but if needed where in the set up would they go ?
Secondly is the Futaba S bus hub just a flash looking three way "Y" lead at £25 a go or is there more in it than meets the eye ?
Thanks for your time
Arthur
Arthur
