esc extension
Posted: December 22nd, 2019, 10:19 pm
by Steve Mansell
I'm aware battery cables to the esc shouldn't be extended without a capacitor bank, but is it ok to extend esc to motor cables.
Looking forward a long way I'd like to build either a hp 0400 or a vickers vimy. The weight of the batteries would need to be as far forward as possible, in the fuselage nose.
Re: esc extension
Posted: December 23rd, 2019, 6:52 am
by Steve Perry
Use thicker motor wires than normal because of the length and twist the 3 together to minimise any interference from them.
If adding capacitors to the battery cables then use Low ESR ones
Re: esc extension
Posted: December 23rd, 2019, 9:16 am
by Tony Collins 1073
Steve, an ESR or equivalent series resistance. If you are using a large electrolytic capacitor with high ESR,
all you have to do is place a low ESR capacitor such as a ceramic 0.1 uF capacitor in parallel.
[ Note, parallel, not series]
Steve Perrys guide of thicker cable twisted together should also be applied
Tony.
Re: esc extension
Posted: December 23rd, 2019, 11:23 am
by Steve Mansell
Many thanks all. It's just a pipe dream at the moment, but my experience with large electric so far has been encouraging, and I do love the ww1 planes!
So far: 1/4 scale Albatros C.iii, 1/4 scale Pfalz D.Xii, and DH 9a on the building board.
Re: esc extension
Posted: December 24th, 2019, 9:14 am
by Steve Perry
Adding a small ceramic .1 in parallel will do nothing for what happens inside non Low ESR capacitors, yes it may well lower the measured ESR of the 2 together but it's like adding a garden hose pipe along side the Mersey Tunnel to help traffic flow
Low ESR capacitors are not hard to find, the rule is to add 2200uf per 4 inches, a quick ebay search gives £6.50 for 5 rated at 35 volts, yes more expensive than £1 for 10 via Aliexpress for normal ones.
You don't need to add 2 X 2200uf for 8 inches, you can just use 1 X 4700uf.
It gets interesting if you go over 35volts as higher voltage caps get harder to find, the trick is to use 2X 4700 in series to get 2200 but at 70 volts
