multi engine set up
Posted: August 27th, 2019, 2:50 pm
by Arthur Fielding
Hi
I have discovered that my Futaba 16SZ radio does not have a multi I/C engine set up program. So I have mixed the throttle channel with a spare one also mixing the trims no problem. How ever the throttle cut function when activated will only work the one servo plugged into the throttle channel. So to stop the motors I have to close the trim till they stop. Not ideaI
Is there a way to get the throttle cut to work on two channels ?
I would appreciate any advise.
Thanks for your time
Arthur.
Re: multi engine set up
Posted: August 27th, 2019, 11:00 pm
by Glenn Masters
Enter FUNCTION menu and change the slave motor channel to also read THROTTLE . . this will mirror the existing channel 3 characteristics . . . Good Luck
Posted: August 28th, 2019, 2:00 pm
by Arthur Fielding
Hi Glenn
Following your advise the throttle cut now works on both servos ,and I can still program them individually for end point /travel etc.
Thank you very much for your help.
Arthur.
