Postby Chris Bradbury » May 13th, 2013, 6:16 pm
Hi guys, just been reading through this thread and there's a mass of very wrong information over the legalities of FPV flying here, so felt the need to chip in, just to make sure that people don't base decisions on the wrong information. To clarify my position, I fly regularlar FPV flights at my club, with zero interference to my club mates, fully insured, legally and safe etc.
Before I start however, I would like to state I'm with you all on the need to crack down on those doing things illegally, so please don't mistake me for someone defending the idiots that can ruin the hobby for all of us, they annoy me too.
So some corrections to information on here to make sure we're clear.
Frequencies:
Currently 2.4ghz and 5.8ghz is legal in the uk for FPV, but the maximum output is not 100mw, its only 10mw on 2.4 and 25mw on 5.8. There are other frequencies available abroad that do sneak in to the UK, such as 900mhz, 1.2ghz and 1.3ghz, which aren't legal for UK use. There is currently enquiries been made by various FPV associations with OFCOM about the option to use selected 1.3ghz frequencies, but this is way off if possible at all. With good aerials on the receiver etc, a range of around 400m is possible legally, but more than that goes beyond line of site anyway.
BMFA insurance:
BMFA insurance covers you as per any normal RC flight for FPV, provided the flight is carried out as per standard ANO regulations and CAP658. You should only need additional insurance if you are doing things for commercial purposes etc, at which point there is far more involved than just insurance. It's my understanding at this time, that the BMFA is yet to receive a single claim as the result of FPV flying. If you are flying safely over a field you should be fine, fly over your neighbours in your housing estate and do so at your own risk. The ANO are the same whether you fly FPV or not.
Current rules of FPV flight:
As with any RC flight, line of site MUST be maintained, which is not possible when looking at a screen or wearing goggles, hence a co-pilot/spotter is required. When the BMFA first looked at FPV flying the buddy-box requirement was imposed, however this has now been relaxed under a General Excemption certificate, (the most recent being April 2013), where you can now fly fixed wing up to a maximum flying weight of 1.8kg and 2.5kg for rotorcraft without the buddy-box, however you will still need a competent pilot as a line of site spotter by your side. Above these weights, the buddy box is required again. The maximum heights is also limited to 400ft irrelevant of weight. There are other restrictions, such as distance flown from other modellers except for landing and so on, but these are mostly what I would class as common sense for the most part.
Issues:
5.8ghz is my personal choice for FPV as I won't interfere with other modellers, but 2.4ghz can and will. The main issue is the 2.4ghz video feed is wide and swamps multiple channels. That said if its on first, the modern Tx's will notice this when switched on and swap channels to avoid this. A current one to watch is the newest GoPro 3 camera, as this is fitted with 2.4ghz for downloading to iPads, so if you know someone with one of these, get them to switch the 2.4ghz setting off. So if someone is flying FPV on 2.4ghz at your site, they must always switch video on first and when all other models are not flying.
At the end of the day, no matter what we do as sensible modellers, there will be people who do their own thing. For example, how many of us have gone slope soaring and been the only one insured? I too am frustrated by people doing things illegally, but even if it was all outlawed it won't stop them. No frequency is as safe as we think, for example I've seen 35mhz pilots shot down by someone switching on from a neighbouring field. 2.4ghz does benefit from systems such as model match, built in fail safes and channel hopping.
My opinion is if you know someone is flying somewhere regularly and illegally, report them.
http://www.altitudephotography.co.ukBMFA Examiner
