Wanted - Zenoah 62 Short Prop Driver
Postby Rob Buckley » October 30th, 2016, 9:50 pm
I'm after a short (about 30mm long) prop driver for a Zenoah 62, has anybody got one lying about unloved?
Rob
Simon Lawson
Re: Wanted - Zenoah 62 Short Prop Driver
Postby Simon Lawson » October 31st, 2016, 8:06 am
Hi Rob, I'm pretty sure I have a new one. I've just got in off nights so Ill take a look this afternoon when I get up. If I have one its yours FOC.
Simon..
Simon Lawson
Postby Simon Lawson » October 31st, 2016, 3:21 pm
Hi Rob, shortest I have is 40mm. If its any good PM me your postal address and Ill pop it in the post.
Simon.
Postby Rob Buckley » October 31st, 2016, 7:44 pm
Simon,
Thanks very much for looking and for the offer, but I need a shorter one really. I've got a 50mm driver at the mo and it's a good inch too long!
Rob
Simon Lawson
Postby Simon Lawson » October 31st, 2016, 7:56 pm
No Worries, Hope you get sorted..
karl lawrence
Postby karl lawrence » November 3rd, 2016, 9:28 pm
I have a z62 with I believe the shorter driver and need the longer one. If mine is the correct size (I'll measure it later) would you be interested in a straight swap for your longer one. Regards karl
karl lawrence
Postby karl lawrence » November 3rd, 2016, 9:48 pm
I've just measured mine and it's 38mm.
Regards karl
Postby Rob Buckley » November 4th, 2016, 7:10 am
Karl, It's probably too long, but I'll do you a swap anyway as I've got a couple of the 50mm ones. PM me your address and I'll stick one in the post.
karl lawrence
Postby karl lawrence » November 5th, 2016, 9:49 am
Pm sent mate. Thanks
stuart knowles 1611
Postby stuart knowles 1611 » November 8th, 2016, 1:17 pm
Hi Rob,
Are Zenoah drivers all the same, i.e. 38 & 62? I've a feeling that this came off a Z38. Will it fit yours?
Postby Rob Buckley » November 8th, 2016, 6:03 pm
Stuart,
The bolt holes in the back flange are 6.75mm diameter and the centres are 46.25mm apart. The back flange is 57.9mm diameter
The hole in the centre is 21.8mm diameter
The prop bolt hole is M10
It might be the camera angle but the one you've got looks a bit different to that
Rob
stuart knowles 1611
Postby stuart knowles 1611 » November 8th, 2016, 6:38 pm
I'll go have another look
stuart knowles 1611
Postby stuart knowles 1611 » November 8th, 2016, 7:02 pm
If its not the same then a blind man riding past on a galloping horse wouldn't notice the difference.
I could bring it to the AGM if you are interested. Let me know if you want to try it.
cheers
stu k
Postby Rob Buckley » November 8th, 2016, 8:11 pm
Stu, Aye if you could bring it to the AGM I'll bring a 62 mag to try it on
Rob
stuart knowles 1611
Postby stuart knowles 1611 » November 8th, 2016, 10:14 pm
OK will do
David Brown
Postby David Brown » November 12th, 2016, 9:58 am
I have one.
