Postby Rob Buckley » November 8th, 2016, 6:03 pm
Stuart,
The bolt holes in the back flange are 6.75mm diameter and the centres are 46.25mm apart. The back flange is 57.9mm diameter
The hole in the centre is 21.8mm diameter
The prop bolt hole is M10
It might be the camera angle but the one you've got looks a bit different to that
Rob
