- RF4D-5.jpg (19.09 KiB) Viewed 6218 times
- RF4D-7.jpg (18.57 KiB) Viewed 6218 times
Due to storage problems I have decided to sell my 33% (12 ft wingspan) Fournier RF4D. It is from the Falcon kit and has been fitted with an aircraft grade aluminium wing tube. A pilot from AH Designs was fitted shortly after these pictures were taken.
- RF4D-9.jpg (49.54 KiB) Viewed 6218 times
It is equipped as follows:-
Engine: Zenoah ZG38
Retract: Fema
Rx: Futaba R6014RS
Batteries: 2x Overlander AF series + 1x Eneloop. All 6v 2000mAh
SM Services battery backer & 3x auxiliary battery units
Elevators: Futaba S3010
Ailerons & Rudder: Hitec HS-645MG
Throttle: Protech P-SD200
Airbrakes: Futaba S3001
Retract: Hitec HS-645MG
U/C Doors: Futaba S9301
Wheelbrake: Futaba S148/8
Weight: 12.36 Kg (27 lbs 4 ozs)
Looking for around £950 but would be happy to split.
Located in the Scottish Borders near Kelso. Phone number 07795 310684
David Middleton
