For sale is my 1/4 scale Hawker Sea Fury built to a high standard using the Jerry Bates plan,currently finished in an Australian Navy Oxford blue scheme it is a well known model which now also benefits from the installation of a set of heavy duty Dave Brown retract units mated to scale double acting oleo legs.
Offered in an airframe only condition with all servos and leads left installed,but excluding Powerbox/receivers/switches and battery systems and radial engine ,it will be supplied with two engine cowlings and a spinner to suit a 2 blade or 4 blade propeller as required by the new owner.
The model has been through the over 20 kg scheme on three occasions,each to suit various sizes of Moki radial,if interested a Moki 250cc or 300cc or 400cc unit together with suitable propellers can be provided at additional cost - additionally should anyone be interested it can also be supplied as a full turn key model ready to fly with a new Moki 400cc installed,along with a 4 blade propeller.
For the airframe only supply as detailed £3500
No offence intended but I am not interested in any part exchanges - in the first instance please respond by PM.
Thanks Trevor Wood LMA 0687
