Carf Models AT-6 "Texan" (all silver-single colour)
Posted: January 8th, 2022, 9:33 pm
by David Heath
Totally untouched kit, as delivered from the factory. All silver colour.
Wingbags included.
Located in Warwickshire, the kits are about as good a quality and prefabricated as you can get. £2500 which is a marked saving on the original cost and of course original pricing before expensive shipping and import duty got involved, I dread to think what the cost would be to get one in the country now.
The kit comes as a standard with the sliding canopy frame and scale flap hinging. As per the Card website It is prepared for the CARF-Models AT-6 E-Gear and the CARF-Models fixed tail gear, as well as the especially manufactured scale wheels. A scale cockpit will also be available soon. Gear and scale cockpit are of course not included in the kit.
The plane is designed around 180 - 250 cc 4-stroke radial engines or 120-150 cc flat twin 2-stroke engines. It is as highly prefabricated as our other high end warbirds, if not even more.
Specs,
Span, 126" (3200 mm)
Length, 87" (2210 mm)
Weight dry, 48 - 53 Lbs (22 - 24 kg) dry
Engine, 80 - 150 cc 2 stroke / 180-250 cc 4 stroke radial
Servos, 9-10 middle to high class servos
Email Glidingaeros@aol.com
