PHENOLIC TUBING
Posted: December 12th, 2023, 9:51 pm
by paul hughes
Posting on behalf of John Braithwaite. He is in need of 4 wing joining tubes for his current build, he reuires 1" ali tube & matching Phenolic tubing 36" long. The usual suppliers are out of stock. If anyone has the tubing they would like to sell to John ,P M me or John himself. Thanks
Re: PHENOLIC TUBING
Posted: December 12th, 2023, 10:08 pm
by Simon Lawson
Hi Paul I have many many meters of Alloy tubing around that diameter. I’ll check the actual OD in the morning. He can make the outer tube by wrapping cloth and epoxy around the tubing. If this helps I can drop off as much as he requires.
Re: PHENOLIC TUBING
Posted: December 13th, 2023, 9:42 am
by IAN TURNEY-WHITE
Paul , Phil Clark at Fighter Aces sells the superb Petrausch Strongal range of wing tubes and sleeves in metric sizes ie 25 mm etc
Best regards Ian Turney-White
Re: PHENOLIC TUBING
Posted: January 9th, 2024, 6:07 am
by Peter Smedley
Slec has now stock just in
Re: PHENOLIC TUBING
Posted: January 9th, 2024, 11:33 am
by paul hughes
All sorted now. thank to every one for the help.
