Large scale cowls & canopies
Posted: January 9th, 2024, 8:02 pm
I am intending to build a 1/3 scale model of a 'Europa'. This means the canopy would be approx 340mm wide x 450mm long x 190mm high ? Cowl would be 340mm wide x 220mm long x 240mm high.
Any idea where I may be able to obtain such items ? These measurements are approximate - I can adjust the build to suit if an item is close to these requirements. At a push I may be able to provide the plugs?
Thankyou
Thankyou
