Wanted - Zenoah 62 Short Prop Driver
Posted: October 30th, 2016, 9:50 pm
by Rob Buckley
I'm after a short (about 30mm long) prop driver for a Zenoah 62, has anybody got one lying about unloved?
Rob
Re: Wanted - Zenoah 62 Short Prop Driver
Posted: October 31st, 2016, 8:06 am
by Simon Lawson
Hi Rob, I'm pretty sure I have a new one. I've just got in off nights so Ill take a look this afternoon when I get up. If I have one its yours FOC.
Simon..
Posted: October 31st, 2016, 3:21 pm
by Simon Lawson
Hi Rob, shortest I have is 40mm. If its any good PM me your postal address and Ill pop it in the post.
Simon.
Posted: October 31st, 2016, 7:44 pm
by Rob Buckley
Simon,
Thanks very much for looking and for the offer, but I need a shorter one really. I've got a 50mm driver at the mo and it's a good inch too long!
Rob
Posted: October 31st, 2016, 7:56 pm
by Simon Lawson
No Worries, Hope you get sorted..
Posted: November 3rd, 2016, 9:28 pm
by karl lawrence
I have a z62 with I believe the shorter driver and need the longer one. If mine is the correct size (I'll measure it later) would you be interested in a straight swap for your longer one. Regards karl
Posted: November 3rd, 2016, 9:48 pm
by karl lawrence
I've just measured mine and it's 38mm.
Regards karl
Posted: November 4th, 2016, 7:10 am
by Rob Buckley
Karl, It's probably too long, but I'll do you a swap anyway as I've got a couple of the 50mm ones. PM me your address and I'll stick one in the post.
Posted: November 5th, 2016, 9:49 am
by karl lawrence
Pm sent mate. Thanks
Posted: November 8th, 2016, 1:17 pm
by stuart knowles 1611
Hi Rob,
Are Zenoah drivers all the same, i.e. 38 & 62? I've a feeling that this came off a Z38. Will it fit yours?
Posted: November 8th, 2016, 6:03 pm
by Rob Buckley
Stuart,
The bolt holes in the back flange are 6.75mm diameter and the centres are 46.25mm apart. The back flange is 57.9mm diameter
The hole in the centre is 21.8mm diameter
The prop bolt hole is M10
It might be the camera angle but the one you've got looks a bit different to that
Rob
Posted: November 8th, 2016, 6:38 pm
I'll go have another look
Posted: November 8th, 2016, 7:02 pm
If its not the same then a blind man riding past on a galloping horse wouldn't notice the difference.
I could bring it to the AGM if you are interested. Let me know if you want to try it.
cheers
stu k
Posted: November 8th, 2016, 8:11 pm
by Rob Buckley
Stu, Aye if you could bring it to the AGM I'll bring a 62 mag to try it on
Rob
Posted: November 8th, 2016, 10:14 pm
OK will do
Posted: November 12th, 2016, 9:58 am
by David Brown
I have one.
