pink foam
Posted: November 12th, 2016, 8:18 pm
by Steve Perry
Does anyone that is going to the AGM have any that they would like to part with ?
It is actually 'knauf eco board', but I am unable to find somewhere that stocks it :(
There are some 8x4 sheets on ebay, but 'buyer collects" a long way from me :(
Re: pink foam
Posted: November 12th, 2016, 8:22 pm
by richard armstrong
http://www.knaufinsulation.co.uk/produc ... floorboard
check the site and they will show dealers close you
Re: pink foam
Posted: November 12th, 2016, 8:24 pm
by Steve Perry
Been there done that, no one stocks it, Wickes used to etc.
Re: pink foam
Posted: November 12th, 2016, 8:58 pm
is there an alternative ?
Re: pink foam
Posted: November 12th, 2016, 9:13 pm
by Steve Perry
Blue is heavyer and white does not carve well.
Re: pink foam
Posted: November 12th, 2016, 10:51 pm
by Mike altham
I contacted knauf and they have stopped manufacture of it. I now buy blue foam from Sig insulation. They have depots all over the uk i think. 8ftx2ft boards.
Re: pink foam
Posted: November 13th, 2016, 3:58 pm
by stuart knowles 1611
Do you need large sheets, for cutting wing core for example or smaller pieces? I can't help with full sheets but I do get large lumps of blue foam offcuts which I have been using as a Balsa block substitute for quite a while now, both in airframes and when making cowl plugs etc.
Any good to you?
Re: pink foam
Posted: November 13th, 2016, 5:55 pm
by Steve Perry
I only need offcuts, I can get blue from the coach builders next door to work whenever they build a refrigerated lorry.
Re: pink foam
Posted: November 14th, 2016, 8:51 pm
by Steve Perry
There is a stack of the pink in Knighton if anyone is in the area.
