JR RD922 2.4GHz DSM2 9 Channel receiver with 3 sats BNIB. 10 available
Posted: August 7th, 2018, 4:19 pm
by martinfairchild
JR RD922 9-Channel Powersafe Dsm2 Receiver Brand New in box. Free P & P £99.99.
The RD922 PowerSafe™ receiver is designed for models using multiple servos that draw excess current or multiple high-torque servos, such as giant-scale airplanes and jet models. It features a robust power bus designed to manage high-current loads, as well as dual 16AWG battery input leads with EC3 connectors for use with larger battery packs.
This makes it possible to support high-current systems straight through the RD922 without the need for a separate power system. As an added measure of safety, the RD922 is designed with a soft switch. Servo current is routed around the switch so, should it fail for any reason, power to the system will not be interrupted.
This patented MultiLink™ receiver design contains a main unit which houses the power bus, and it includes 3 remote receivers which come with one of each: 9”, 12” and 24” remote receiver extensions. The dual path redundancy of Spektrum’s patented DuaLink® technology, plus the fact that each of the receivers is mounted in a slightly different location, exposes each to a different view of the RF environment and creates a bulletproof RF link in all conditions.
Also, in the highly unlikely event that both of your batteries should ever drop below 3.5 volts, new Fast Reconnect circuitry in the RD922 provides for control recovery the moment adequate voltage is restored. There is absolutely no delay.
You can add an optional fourth remote receiver (JRPRR121) to further enhance the receiving capabilities of the system for more complex aircraft.
In addition to Spektrum’s exclusive SmartSafe™ technology, the RD922 gives you the option of using standard user preset fail-safe settings.
Dual 16AWG battery input leads with EC3 connectors for use with larger battery packs Includes a soft switch Includes 3 remote receivers Features SmartSafe technology plus preset fail-safe Compatible with all JR and Spektrum DSM2
Any questions text or call Martin on 07960410340
