Glens 30% CAP 232 with Zenoah 62 - Now SOLD
Posted: August 18th, 2018, 12:18 pm
by Chris Hurst
For sale is my Glens 30% CAP 232 complete. Just add your receiver to fly. It flies beautifully and is an ideal introduction to larger models.
The fuselage, cowl, canopy and tailplane are all in decent flying order, with just a few minor signs of age. It has a pair of virtually new wings fitted and will also come with another set of older (but perfectly useable) wings as spares, one of which has clearly been repaired by a previous owner.
It has a Zenoah 62 that runs reliably and has decent Hi Tec programmable digital servos on all flying surfaces plus a couple of more ordinary servos on throttle and choke. It has two decent Sub C sized batteries and two Futaba heavy duty switches. Appropriate wooden prop and aluminium spinner. The spinner has a few marks but is perfectly serviceable.
The Zenoah 62 is fitted with the engine half of the Easy Start system but I need to keep the external box as I use it with other models. Having that fitted doesn't stop you from starting the engine normally (if you have the knack and a strong arm!!) but if you wanted to use the Easy Start you would need to buy a box separately (about £40 to £50 from memory).
I also have the spats but these do need painting.
Now SOLD
07930 758495
GC right.jpg (92.02 KiB) Viewed 2201 times
GC Left.jpg (94.02 KiB) Viewed 2201 times
