Scale Exhaust for DA85, DLE85, DLA85 new in box.
Posted: September 3rd, 2019, 6:48 am
RRP £199.99 so £55.00 including P&P is a bargain.
Made from aluminum for the Ripmax Flying Legends P51 Mustang, but will fit in most round cowls with easy, as this rap-around the back of the engine style exhaust, very lightweight, with a reduced noise signature without loosing any power. Depending on how you mount the exhaust to the motor box or firewall you may need extra mounting/supporting straps as some have cracked where the manifold meets the silencer in the past so recommend adding more mounting straps.
Center to Center of the mounting bolts are 42mm,
From the front of the manifold to the rear of the exhaust is 185mm,
Height 93mm, height to the end of the outlets 120mm,
Depth 103mm,
wide 178mm,
Only have a few left so be quick.
Depth 103mm,
wide 178mm,
