SOLD SOLD SOLD New Hangar 9 46% TOC Ultimate
Posted: July 17th, 2021, 2:45 pm
by Richard Thomas
Probably the only NEW 46% TOC Ultimate left in the world.
Hangar 9®
46% TOC Ultimate 10-300
£5,000 No Offers
Designed by Mike McConville 8 times ‘Tournament of Champions’ competitor with over 200 Pattern and IMAC awards. This model is all new, never flown and fitted with the ultimate radio control model accessories and will perform all IMAC schedules and 3D Aerobatics and cost over £5,500 with the best spec available. Only requires TX/RX and batteries to get in the air.
Wingspan 100 inch 2540mm
Length 110 inch 2794mm
Weight 21Kg approx ‘as is’ but can be reduced with smaller engine to under 20kg
Engine ZDZ 210cc B2RV
Specifications:
Servos: 14 x ‘Hitec’ Digital Coreless High Torque HS5945MG control surface servos with HD aluminium control arms.
Linkages: All ‘Rocket City’ HD connections (the best on the market).
All Titanium ‘ProLink’ pushrods.
5 x ganged ‘Nelson’ bell cranks rudder system.
Radio: ‘Duralite Plus’ Power Box Professional 40/24 with dual intelligent voltage regulators, all servo pulse amplifiers, Dual battery ports for Lithium Ion or Lithium Polymer power packs (not supplied).
Dual redundancy fail-safe switch.
HD silicone servo cables.
Dual RX ports (RX not supplied).
Engine: ‘ZDZ’ 210B2RV (boxer)
RV carburettor exits inside fuselage providing stable air pressure and constant running through any manoeuvres.
Silencers: ‘Krumschied’ twin headers and cannisters with smoke ports.
Props: 2 x ‘Menz’ 34/12 (1 spare).
Fuel tanks: ‘Du-Bro’ 50oz petrol with anti-syphon valve.
‘Du-Bro’ 50oz smoke and pump.
Spinner: ‘Tru-Turn’ 6” Alloy Ultimate.
Undercarriage: Carbon Fibre mains and tailwheel bracket.
‘Du-Bro’ Superlite mains wheels.
Scale Pilot: ‘AH Designs’ civilian bust.
Wing Bags: 4 x Luxury quilted best spoke made
Note: This model is world renowned as a high performer and construction. It is all new and not currently licenced above 20kg in its current configuration but there is no reason for it not to pass inspection.
Model is being sold reluctantly (as are all my other aircraft and workshop equipment details to follow later) due to long term illness.
Re: New Hangar 9 46% TOC Ultimate
Posted: March 3rd, 2025, 5:21 pm
by Richard Thomas
NOW SOLD
