DLE 55RA Silencing
DLE 55RA Silencing
Postby John Greenfield » December 13th, 2018, 6:27 pm
Hi Guys
Has anyone tried exhaust bungs (pepper Pot) in the stock silencer supplied with the DLE 55RA and does it work to quieten the motor? I can accept some power loss but have very little room to fit a bigger silencer. I have been told that just blocking one outlet of the silencer will do the same job as a bung ??? but I can't see how this would be the case.
If anyone has any real world experience of these bungs please let me know.
stuart knowles 1611
Re: DLE 55RA Silencing
Postby stuart knowles 1611 » December 13th, 2018, 7:07 pm
I can't speak about the DLE 55 but I have two engines with Pitts style Chinese silencers each with twin outlets. Removing one outlet completely certainly helps and took some of the bark of the noise. The other is on a 26cc two stroke and I blocked off one hole and also reduced the diameter of the second to (Off the top of my head) 10mm The engine is being strangled somewhat but for the model it is in, it still has plenty of power and it is probably the most quiet of the fleet.
Crude and unscientific? - probably but also easy and effective.
There was some discussion a while back about an article on 'The Sid King method of silencing engines' Did it ever come to light? I don't remember seeing it
Ken Roddham
Postby Ken Roddham » December 13th, 2018, 7:21 pm
John - two or three years ago I made a couple of exhaust restrictors for the engines in Ted Allison's Rapide. The engines were two DLE 55's.
We tried various configurations for hole pattern and size and finished up with pepper-pot arrangement of five 3.3mm holes in each restrictor. The restrictors were an inch long and secured by grub screws inside the exhaust outlet pipe.
No notable reduction in engine performance and a big reduction in noise.
Ken
DLE 55 restrictors.JPG (99.74 KiB) Viewed 12236 times
Barrie King
Postby Barrie King » December 13th, 2018, 9:57 pm
I found 2 closely fitting lengths of Ali tube that would push into the outlets, then drilled about 6 holes in each one in the part that would be in the silencer body, pushed them in and secured with a cross bolt. Took about 10 mins and took most of the cackle out.
Mike Ellis
Postby Mike Ellis » December 14th, 2018, 12:06 pm
I sent the complete article to Dave for him to publish as he requested.
At present it has not appeared.
The Sid King silencer will without doubt solve your problem as the so called pepper pot system is not how sids work !! Its based upon a gun silencer !!
I can supply the article if required as Ive made many of these and I swear by them .
Postby Tony Collins 1073 » December 14th, 2018, 2:02 pm
June 9th, 2018, 7:51 pm
Hi Paul
There will be an article on the Sid king silencer coming in the LMA journal shortly. These will definitely work to make your engine a lot quieter.
If you want a copy, I can email it to you before the journal comes out.
Mikes reply to Paul Hughes in June.
I am quite sure this article would be of interest to many members. If it has not appeared I cannot understand why.
Peter Siggins
Postby Peter Siggins » December 14th, 2018, 3:23 pm
Hi John I have made a few of Sid King silencers - mostly for Zenoah 38’s - work very well
Last one I made was for a Chinese CRRC 45 - quietened the bark completely - very successful ,should work well on a DLE 55 ,far better than pepper pots which I found restricted the engine and caused some over heating.
Postby John Greenfield » December 15th, 2018, 10:30 am
All
Thanks for your replies. Seems like I need to build some of the "Sid King" type silencers. Now I need to see the article to know how !!!
Postby Bob Thompson1894 » December 17th, 2018, 9:04 am
Mike Ellis wrote:I sent the complete article to Dave for him to publish as he requested.
Over to you Mike. I would be interested too.
Mike Ellis
Postby Mike Ellis » December 17th, 2018, 9:09 am
Hi bob
Send me your email addy and I will send you the info and pics of how to do it.
Mike
Mike Ellis
Postby Mike Ellis » December 17th, 2018, 8:09 pm
All members please note that I will need an email address in order to send the info on the silencer to.
My email addy is:
roadkingmick3945@aol.co.uk
Mike
David Berry
Postby David Berry » December 17th, 2018, 9:31 pm
Mike Ellis wrote:All members please note that I will need an email address in order to send the info on the silencer to.
My email addy is:
Mike
Mike was great earlier in the year when I raised the subject of an exhaust for an upright Z38.
He kindly sent me all the details to fabricate the Sid King silencer although in the event I solved my problem another way
Thanks again Mike
Postby Bob Thompson1894 » December 18th, 2018, 8:20 am
Mike Ellis wrote:Hi bob
Mike
Done and thanks for the quick reply with the info, Mike.
Postby John Greenfield » December 18th, 2018, 9:35 am
Big thanks to Andrew Taylor and Mike Ellis who both sent me the Sid King article.
Having read it all it does seem to be something we should run in the Journal if Sid would give permission.
John Evans
Postby John Evans » December 18th, 2018, 4:16 pm
Thought I had seen this in a magazine not too long ago correct me if I am wrong.
Could do with the info as well
Peter Siggins
Postby Peter Siggins » December 18th, 2018, 7:12 pm
I made a double piped one for a CRRC 45cc - a few pics show a half made one - the box section and tubing bought from B&Q plus some scrap steel plate for ends and blanking pieces.All silver soldered together.
Mike Ellis
Postby Mike Ellis » December 19th, 2018, 10:38 am
Hey Pete, now thats a differrent version of Sids silencer !! Well done m8!!
