Zenoah change of rotation
Posted: April 29th, 2025, 7:03 am
Hi,
What's required for changing the crankshaft rotation on a Zenoah with electronic ignition, is it just a different timing pickup/bracket or is there more to it?
Anyone had experience with counter rotating Zenoah's and anything special that can be done with the prop bolt coming loose like fitting dowels or multi bolt prop hub fitting?
Thanks for your time
