Workshop Images please?
Posted: April 25th, 2012, 9:48 pm
by Simon Wright
Just moved house and now have a decent sized double garage to set up as my workshop.
I effectively have a clean sheet and could do with some ideas and inspiration before it fills up with planes and other household items.
Re: Workshop Images please?
Posted: April 27th, 2012, 7:14 pm
by David Middleton
Hi Simon
Here are some pictures of my garage/workshop. It measures about 20ft x 18ft and as you can see there's room to have a car in and still be able to build. In the winter when it's too cold to build I collapse the main bench and can then get a second car in and still have access to the two smaller benches for minor maintenance.
Hope this helps.
David
Posted: April 27th, 2012, 7:36 pm
by Simon Willey
Thats not a workshop its an operating theatre :D
Si
Posted: April 27th, 2012, 8:39 pm
by Phil Clark
Before I messed it up.............
Garage measuring approx 22ft x 10ft. Single thickness brick construction with 2" rockwool and 3/4" ply on all walls. Insulated 'Horman' garage door, plasterboard on the ceiling with 6" of rockwool between it and the flat felt roof. Still gets cold in the winter, but 30mins with a small oil filled radiator has is usable.
......7 years later it's a bit full.
Posted: April 27th, 2012, 9:09 pm
by stewart clifford
David, far too tidy, what the hell is that car doing taking up valuable aeroplane space? :lol:
Posted: April 28th, 2012, 4:01 pm
by David Middleton
Stewart
It soon gets moved out when more space is needed!
Posted: April 29th, 2012, 9:33 am
by Simon Wright
Thanks for the images. Very nice workshops guys. The central workbench seems a common idea that works well.
Already realised just how cold the garage can be so will take a look at boarding the walls and adding lots of insulation.
Posted: April 29th, 2012, 1:45 pm
by Simon Willey
I used some kitchen unites as the centre bench in my 5x4m workshop . I made a wider top and on the back of the unites I built 6"deep storage shelf's that take ice cream containers filled with me junk and stuff..
Works really well. I bolted the unites together and it can be moved around as one if needed. A centre work space is a must I have found.
There is a 2ft bench on two walls and a 3ft one on the third all full of junk most of the time.
Heating is via a gas boiler and radiators, about 3 million plug sockets everywhere. Fully insulated and lined out in 9mm MDF then pained. The floor is 1" white polystyrene with 3/4 green chipboard flooring on top.
I have also put a half decent HiFi system in there as well and a decent compressed air supply that will run most air tools.
Simon
Posted: May 1st, 2012, 2:05 pm
by Stuart Bishop
Hi all just some of my workshop (mancave) all i can say think of the size you want & double it yes :o yes i my need help :lol:
i started of with a shed 6x2.4m fine for 2 years then needed more room so that became the hangar & i built a building / dust room 5x2.4m & the main shed 9x6m
with tv dvd hifi mini bar & beer fridge, sofa bed when it gets to late to snick in doors :shock: pool table is my centre bench thats what i told her indoors
img (5).jpg (27.18 KiB) Viewed 9529 times
yes & a sink with hot water
img (2).jpg (24.04 KiB) Viewed 9529 times
& a pulley system
img (7).jpg (19.24 KiB) Viewed 9529 times
dust room
img (1).jpg (21.42 KiB) Viewed 9529 times
img (6).jpg (22.22 KiB) Viewed 9529 times
a good spar part wall
img (8).jpg (34.2 KiB) Viewed 9529 times
so if any ones ever passing by jct11 on the m40 stop by for a coffee
Posted: May 1st, 2012, 5:53 pm
by Simon Wright
Nice Man caves by all.
Attached images show the starting point of a nearly empty workshop when we moved in. it is now filling up with all sorts of junk as we continue unpacking and I still dont have a plane here....
Any suggestions please?
