Compression springs
Posted: August 15th, 2014, 10:19 am
by Mike altham
Does anyone know where I can get two compression springs from? Need to be able to slide over 3mm threaded rod (3.5mm) and about 20mm long. Need to be quite strong as they are going to be on the nimrods nose leg servo saver.
Re: Compression springs
Posted: August 15th, 2014, 5:55 pm
by Nigel Cox
I've got a box of assorted springs from Halfords ( code HBB134) there's a couple that might be suitable just depends if they will be stiff enough
edit: To compress them by 50% takes 280 ~ 350 grams
Posted: August 15th, 2014, 8:16 pm
by paul needham
