dural aluminum
Posted: October 3rd, 2014, 7:39 pm
by richard armstrong
please can somone point in the direct of where to purchase dural aluminium in 1/4"/6mm,
i need it for an undercart, 15kg model, cessna 182
also how would you go about bending it, is there a required method
Re: dural aluminum
Posted: October 4th, 2014, 8:09 am
by barrie burton
Richard,question should be in technical forum,as is the answer if you use the search button.
Material supplier is:
John Keatley Metals
Birmingham
0121 236 4300
Material required is 2014 T6
They will cut to size and post to you.
Rub soap on back face of the metal,at the bend position.Heat with a blow torch on the front face until the soap turns black,then bend around a radius.
I clamp the metal in a vice between the jaws and a 1" diam steel bar,I then clamp a long bar the the u,cart and bend the leg to the required angle.Dont forget,it is hot.
Barrie B
Re: dural aluminum
Posted: October 4th, 2014, 10:23 am
barrie burton wrote:Richard,question should be in technical forum,as is the answer if you use the search button.
John Keatley Metals
Birmingham
0121 236 4300
Barrie B
thanks barrie
Re: dural aluminum
Posted: October 4th, 2014, 1:24 pm
by Peter Siggins
Hi Richard,
Aluminium warehouse have a good website for T6 etc - very prompt deliveries
Best of luck
Re: dural aluminum
Posted: October 4th, 2014, 11:19 pm
Can i just point out here, that the working time of T6 is at best, limited when soap blackeningly hot, if all you have is a hammer, and a small vice, your going to struggle, better to buy a commercially available item, or a composite one,
Re: dural aluminum
Posted: October 12th, 2014, 4:36 pm
Alan Cantwell 1131 wrote:Can i just point out here, that the working time of T6 is at best, limited when soap blackeningly hot, if all you have is a hammer, and a small vice, your going to struggle, better to buy a commercially available item, or a composite one,
£120 imported from usa, £30 for ali, i have oxy gas mix, and soap the shape is quite simple to bend
Re: dural aluminum
Posted: October 12th, 2014, 6:37 pm
Re: dural aluminum
Posted: October 12th, 2014, 6:47 pm
i am a total numbty i completely forgot about carbon copy, DOH!
