Trunking for servo leads
Posted: May 12th, 2015, 4:50 pm
After some comments from Phil some time back I have opted for plastic oval trunking for my 1/4 scale Chipmunk. This MK Oval Conduit came as a 3m length and is 16mm by 10mm oval section. It weighs 44gm per metre. Mine came from B & Q and it is available in 2m lengths as well. There were already 6mm holes in the ribs of my laser cut kit and I opened these up with the small drum sander in the Dremel. This size allows the normal Futaba/JR connectors to pass through readily.
