AVRO Shackleton
Posted: November 30th, 2017, 8:37 pm
by richard armstrong
i would like to ask if anyone has drawn up plans for a Shackleton or know of a set of plans in any scale or has 3 view plans for the airframe?
Re: AVRO Shackleton
Posted: November 30th, 2017, 10:56 pm
by paul hughes
Richard, as you know the AVRO Shackleton is a modified AVRO Lincoln which was a modified AVRO Lancaster all great Manchester built aircraft. There is one in the MOSI at Manchester, You could also get information from the AVRO Heritage Museum at woodford, a good day out and you will learn loads. Or You could draw your own quite easily.
Re: AVRO Shackleton
Posted: December 1st, 2017, 12:08 am
hi paul thanks for the info
we have Shackleton here in Newark museum, that is under restoration for static display, i was hoping to use that,
did not know that is was a mod from a Lincoln, that helps me a bit
Re: AVRO Shackleton
Posted: December 1st, 2017, 7:48 am
by Rob Buckley
Here's One...
Re: AVRO Shackleton
Posted: December 1st, 2017, 7:54 am
thanks rob
Re: AVRO Shackleton
Posted: December 1st, 2017, 8:25 am
by David Berry
Richard,
There is also a Shackleton WR963 at Coventry Airport which I believe does regular engine runs and taxying, with an aim to get it airworthy again.
See www.avroshackleton.co.uk
