Evolution 260cc radial problems.
Posted: September 15th, 2019, 8:24 am
Hi chaps can I get a bit of advice of were to go from here. I bought a Evolution 260cc radial engine two years ago from a well known UK model shop to go in my 1/3 scale Stearman but due to a few health issues it sat in my bedroom for over a year and I have just this year finished the aircraft.so was able to get the engine fitted and tested.
We had been running the engine with top quality fully synthetic oil at a ratio of 32/1 it was just coming up to 55 mins of run time when it seized. Only just got upto ¼ to ½ throttle so not over revved.
On inspection when we opened the engine up there was no shortage of lubrication, we found that one of the little ends had snapped in two letting the roller bearing fall into the engines causing lots of damaged, the big end on this rod did not show any signs of heat build up so this had not seized. Damaged caused.
1 snapped con rod.1 bent conrod, damaged piston, damaged cylinder. And other things .As horizon hobbies were the importer at that time and only give you a 12 months warranty it is of course out of the time. Will I be wasting my time trying getting any redress from either the shop or the importer?
If this is the case any ideas were to get spares from so we can rebuild it “Gutted”
