After everything being test assembled at Gaydon,i have decided now to complete each section to a state for white primer----the first section to come into the building shed is one wing panel---this has been finished and glassed on top surface,and this last week,all servo boxes built and servos and linkages fitted.Pics to follow.
- 2011-10-29 21.08.29servo1.jpg (17.98 KiB) Viewed 13433 times
- 2011-10-29 21.08.45servo2.jpg (18.21 KiB) Viewed 13433 times
Today,the bottom surface was glassed ,and servo hatches etc fitted.remaining now are a couple of radio hatches,and fit and wire the control valve for the retracts and brakes--thats tommorrows evenings job.
- 2011-10-31 16.47.491st wing underglass.jpg (19.54 KiB) Viewed 13433 times
- 2011-10-31 16.49.071st wingunderglass2.jpg (17.94 KiB) Viewed 13433 times
The retracts have been returned to Alex at Chester for final finishing and polishing,and after weight testing at Gaydon,the final spring s will be fitted ---once these are returned,they will be finally fitted
