Sam and myself have now split tasks to get the plane finished for Elvington. Sam is fitting all the servos and linkages and I am doing the cowl, prop, spinner and other bits.
Here's Sam trying to work out how to get 4 servos into there to control the elevators.....
- IMG_3748small.JPG (34.57 KiB) Viewed 14464 times
I have been continuing cowl building. I had previously made a foam blank and glassed it. I then spent the next year sanding it smooth, before removing the blue foam. The foam actually came out quite easilly due to a little tip I was told - completely cover the blue foam in brown wraping tape before glassing. The foam just pulled out in chunks....
- IMG_3745small.JPG (58.09 KiB) Viewed 14464 times
Today I glassed the inside of the cowl to give it the right strength and built in a lite ply piece in one side ready for cutting an access door to get at batteries....
- IMG_3746small.JPG (52.21 KiB) Viewed 14464 times
The inseret was weigthed down to get a good bond....
- IMG_3747small.JPG (47.57 KiB) Viewed 14464 times
And while Sam and me were working in the garage, this was the view outside!!...
- IMG_3751small.JPG (34.45 KiB) Viewed 14464 times
