Nice work, I'm building a 30% Pitts Special at the moment as a prototype or practice for a 50% version in the future. The 50% version is on the CAD table at the moment but the 30% had some of it's paint this week. Must try to arrange some photos for on here.
Hi Everyone, I'm afraid I'd lost enthusiasm during the summer and had too many projects on the go. The model is far from finished but I've just started back on the build, just joined the top wing panels. I'll put some pics up as soon as I get some worth uploading. Still looking for a suitable engine though, I'd really like to put a twin up front to keep the vibration down to a minimum. Dave.
Today I've just been checking the fit of wings and tail feathers, checking alignment of wings to fuselage, tailplane to wings, and marking the position of the interplane strut half ribs so I can get on with finishing sheeting of top and bottom wings.
First fit assembly to check decalage.
38. Assembly to Check Decalage, Position of Cabane and Interplane Struts..jpg (41.65 KiB) Viewed 12797 times
Setting the Tailplane to 0 degrees using a Wixey Digital Angle Finder to use as a comparitor.
39. Setting Tailplane to 0.0 Degrees.jpg (43.62 KiB) Viewed 12797 times
40. Setting Tailplane to 0.0 Degrees.jpg (44.3 KiB) Viewed 12797 times
Comparing the upper wing incidence to the tailplane.
41. Checking Upper Wing Incidence Using Digital Angle Meter.jpg (43.18 KiB) Viewed 12797 times
42. Checking Upper Wing Incidence Using Digital Angle Meter.jpg (34.16 KiB) Viewed 12797 times
