I thought it might be time for a bit of an update!
So, first up is a cooling duct as the cylinder head is right up tight against the firewall. A hole in the firewall and sheet duct to get the air past the servos and venting out of the cockpit. The duct is in two halves and sandwiches the firewall.
- Duct 7.JPG (344.33 KiB) Viewed 12056 times
Next up was mounting of the throttle and choke servos. Folded up out of yet more sheet steel, silver soldered and bolted in position.
- Throttle & Choke (5).JPG (373.49 KiB) Viewed 12056 times
I've managed to shoe horn the standard Z62 exhaust in and added an additional cowl mounting ring to support the cowl and the side cheeks.
- Cowl Ring (11).JPG (51.94 KiB) Viewed 12056 times
Along with other DP aircraft it's had a couple of outings to the Shuttleworth Collection fullsize air displays this year and most enjoyablle they were too.
- OW July 15 (1).JPG (74.07 KiB) Viewed 12056 times
I've tidied up the wing panels (all six of them!) and tried to get them all up to the same state and started on forming the ailerons prior to cutting them free.
- Wings 5 (1).JPG (58.38 KiB) Viewed 12056 times
The cowling side cheeks and top have been formed out of 18swg aluminium sheet and have made a big difference to it's appearance (at last!) I think.
- Top Panel (4).JPG (43.69 KiB) Viewed 12056 times
- Top Panel (5).JPG (42.27 KiB) Viewed 12056 times
And finally, I've started making the Vickers machine gun. Fabricated from Litho plate for the barrel cover, Nickel silver sheet for the back end and aluminium turnings for the front and rear of the barrel cover.
- Front Ring (12).JPG (42.64 KiB) Viewed 12056 times
I've built up a bit of momentum at the moment, who knows, if I keep it up it might even be finished next year (I can but hope!).
Alan
