1/12 scale Avro Vulcan B Mk2.
RegHomden
Postby RegHomden » August 3rd, 2009, 2:26 pm
I am currently building a 1/12 scale Avro Vulcan B Mk2
This was not built from a kit. I had to design it from photographs, the main dimensions and a very small (a5) 3 view diagram. That is why I am including photos that illustrate the various stages and methods of construction.
It has a wingspan of 2.82M length 2.68M and is .69M high.
Full Skeleton.jpg (41.6 KiB) Viewed 10677 times
Vulcan Wing Underside.jpg (46.87 KiB) Viewed 10671 times
Jason Griffiths
Re: 1/12 scale Avro Vulcan B Mk2.
Postby Jason Griffiths » August 3rd, 2009, 3:46 pm
Hiya
Now how good does that look :D very nice looks like a good bit of craftmanship there.
How long has it took you to get to this stage ?
Thanks 8-)
RegHomden
Postby RegHomden » August 3rd, 2009, 4:21 pm
Hiya Jason,
and thanks for the compliment.
As for how long it has taken me -----
I spent about 2 weeks trying to find/acquire plans or a kit on the internet but all that I came up with was an A5 3 View and a bunch of photographs.
So then I spent about 6 weeks drawing all of the ribs / formers (that were to cut from light ply ) and printing them onto A4 sheets. I don't have a CAD program so I used The Visual basic Designer. Then I pasted the printed ribs onto card and cut them out so that I could draw round them onto light ply.
Cutting out the shapes with a jig saw took me about another 4 weeks.
Assembling - up to the stage that you see so far took about 5 weeks.
So - in total that is 17 weeks in total.
I have now finished planking it (that took about six weeks) and I an adding a photo of that
Reg
Note - the top half of the nose is removable - as are the wings
Av_ Planked.jpg (48.8 KiB) Viewed 10646 times
Jason Griffiths
Postby Jason Griffiths » August 3rd, 2009, 4:49 pm
Reg that's bleedy lovely 8-)
Thanks 8-)
stuart cotgrove
Postby stuart cotgrove » August 3rd, 2009, 5:04 pm
My goodness, that is lovely. What motive power is planned?
RegHomden
Postby RegHomden » August 3rd, 2009, 10:30 pm
Hi Stuey,
I am not sure if I should use 4 EDFs or a jet. The problem with a jet is where or how to do the jet pipes. At the moment I have four jet pipes, each of 60mm diam. Any advice would be very much appreciated. As it is, without servos, engines or receiver it weighs 9 kilos. That may sound slightly heavy but most of it is double skinned ( 2 layers of 2mm balsa). I live in madrid and all ao my materials come on metric dimensions.
I have very limited experience with building model aircraft. So far I have built :
A 1/7th scale Sea Fury form Tower Hobbies that was a superb kit with instructions that enabled even a novice to build a fantastic aircraft that flies fantastically.
A 1/6th Scale Spitfire from a crap kit that lacked many essential parts and almost no instructions. The good news was that, being so bad, it taught me a lot and now it looks fantastic and flies even better than the Sea fury - and gave me the confidence to tackle the Vulcan fro0m scratch.
Just thought you might like to see the undercarriage that I have just built :-)
I know that the full size vulcan has 8 wheels on each main leg but .......
RegHomden
Postby RegHomden » August 10th, 2009, 3:17 pm
A bit more progess. It is now fully painted and then main decals are in place.
You can get a rough idea of its size from my shadow in the photograph
Jason Griffiths
Postby Jason Griffiths » August 10th, 2009, 8:13 pm
Looking good there is it ready to fly :?:
Thanks 8-)
RegHomden
Postby RegHomden » September 7th, 2009, 8:02 pm
Not quite ready to fly yet. I have installed every thing except the turbines and fuel tanks. So far I have an AUW of just over 10Kg.
After a lot of researching, mainly what other builders of large jets have done, I have decided to power it with two Wren 70s. This will give me a bit more power than I really need 14Kg of thrust for a Total Loaded weight of around 30Kg. But then with all that thrust and the massive wing area, my take off run should be really short. Besides, a Full size Vulcan has a massive thrust to weight ratio - does it not? :-)
