In between playing around with rib tapes, I have been slowly getting the large 'trousers' mounted. Quite a tricky affair, but I think I am about there now.
- IMG_5118.JPG (112.75 KiB) Viewed 16988 times
I'll need to look at baffles next, but should be plenty of cooling.
- IMG_5119.JPG (59.69 KiB) Viewed 16988 times
I have made some catches for the opening hatches. Similar to the full size (I admit they are not 100% in the interests of usability). Telescopic sections of brass tube with a spring...
You can also see the 2 (four per spat) bolts holding the rear section in place. I'll replace these with domed bolts when I can.
- IMG_5120.JPG (72.83 KiB) Viewed 16988 times
1 quarter turn allows the fastener to release... (Note the two rivets to hold the catch closed)
- IMG_5121.JPG (65.68 KiB) Viewed 16988 times
...and easy access to fueling ports, charging jacks and the carb needles.
- IMG_5122.JPG (78.4 KiB) Viewed 16988 times
I'm sorry, but I didnt take any photos while building these (I was enjoying it too much to stop!) There is a main brass tube shaft with the domed section slotted and soldered in. A telescopic section of brass is fixed into the wooden support, spring added and then a telescopic section of brass soldered on to seal the unit up......
- IMG_5123.JPG (49.68 KiB) Viewed 16988 times
You can make out the blind nuts for the holding the front section in place....5 bolts here.
- IMG_5124.JPG (63.53 KiB) Viewed 16988 times
As per the real thing, a support for the top of the cowl made out of brass sheet. It is slightly off centre to avoid interfering with the cowl hinge...it doesn't look so obvious in real life!
- IMG_5117.JPG (89.52 KiB) Viewed 16988 times
