DC 3 Dakota
David Jones
Re: DC 3 Dakota
Postby David Jones » March 11th, 2014, 12:58 pm
We had a great day at Woodford yesterday where the model was test flown again by Dave Johnson. She's now had eight flights, all of which she has passed with "flying" colours (pardon the pun, but I couldn't resist that one). Dave Parry was on hand to take some pictures, so here are a few I've selected for the forum. I've just got to do one or two tiny mods' then the model will be put to bed, ready for East Kirkby.
David Jones
Re: DC 3 Dakota
Postby David Jones » March 11th, 2014, 1:02 pm
Some more photos.
David Jones
Re: DC 3 Dakota
Postby David Jones » March 11th, 2014, 1:05 pm
And finaly.
Craig Green
Re: DC 3 Dakota
Postby Craig Green » March 20th, 2015, 6:03 pm
David
What size props are you using on the G-38's, and are you happy with the performance?
Nice build, she looks great.
Craig
Re: DC 3 Dakota
Postby Alan Cantwell 1131 » March 20th, 2015, 11:33 pm
The original props were bolly carbon three bladers, 18x10, these were lost when Dave had an axle seize, refitted wirh menz three pladers, again, 18 inch, but not sure if the pitch is 8, or 10, the 38s are way sufficient, they are exactly what a twin wants, easy starting no fuss petrols, that just run for ever, We also have them in Alans B25, again, a great combination,
David Jones
Re: DC 3 Dakota
Postby David Jones » March 21st, 2015, 9:57 am
Hello Craig, as Alan has stated, initially the model flew brilliantly with the 18 x 10 "Bolly" carbon props. These are now too badly damaged to fly, but would be okay for static display. I've decided to try a pair of MenseS 18 x 10 wooden three bladers, these work out at less than half the price of carbon props. The model hasn't flown on these yet, but she will be test flown before we take her to East Kirkby. I'm quite confident these props will be okay.
Alan Greave's B25 has the same ZG38 magneto engines as the Dak, and it flies great on 20 x 8 MenseS two blade props. That's the way I was going to go but, as you will be aware, the engines on the Dak are a lot closer to the fuselage, hence the 18" three bladers (I think they look better anyway, espescially when they are painted black with yellow tips). I'll drop you a line when the Dak has flown again. Jonesey.
Craig Green
Re: DC 3 Dakota
Postby Craig Green » March 23rd, 2015, 3:17 am
Thanks for the info Dave.
If am currently building a 1/6 Lancaster, thinking of props for my G-38's.
I have flown my 1/6 He 219 with 18 x 8 props, if flew okay but am also looking for an alternative prop with more performance. Also the look of three blades are much nicer.
Craig
richard armstrong
Re: DC 3 Dakota
Postby richard armstrong » December 21st, 2015, 7:28 pm
hi dave
do you have photos of the Flaps horns and how they are operated please pm them to me
Re: DC 3 Dakota
Postby Alan Cantwell 1131 » December 21st, 2015, 9:27 pm
Great to see the Dak again, but so sad to see woodford with all the buildings and runway intact, sigh, all gone now, sigh
David Jones
Re: DC 3 Dakota
Postby David Jones » December 22nd, 2015, 12:40 pm
Hi Richard, I've used Dubro large scale control horns on all the control surfaces. They are the big black plastic ones that you buy in pairs and they are screwed into plywood hard points. If you scroll back to page 5 of the build thread and look at the photos posted on 7th and 25th February you will see the painted wing panels on the bench. The aileron servos are mounted upright with the top protruding above the lower surface. All four flap servos are mounted on their sides inside hatches, with just the servo arm protruding through the hatch cover. Hope this helps. All the best, Jonesey.
richard armstrong
Re: DC 3 Dakota
Postby richard armstrong » December 22nd, 2015, 12:48 pm
David Jones wrote:Hi Richard, I've used Dubro large scale control horns on all the control surfaces. They are the big black plastic ones that you buy in pairs and they are screwed into plywood hard points. If you scroll back to page 5 of the build thread and look at the photos posted on 7th and 25th February you will see the painted wing panels on the bench. The aileron servos are mounted upright with the top protruding above the lower surface. All four flap servos are mounted on their sides inside hatches, with just the servo arm protruding through the hatch cover. Hope this helps. All the best, Jonesey.
that helps mate
need to understand how this was done, KISS, is the best practice
Users browsing this forum: No registered users and 25 guests
